LIGHT BAR SWITCH
Missouri Ozarks
To start with I installed a Factory Light Bar Switch shortly after buying Rocky. I did not do any thing past installing the Switch. Checking out the Switch's today I discovered that the factory Light Bar Switch has FOUR Wires. The Switch is wired into a factory Relay. The Relay should only need a Power In wire from the switch. So the Light Bar Switch should only need TWO Wires, Power In, and Power Out to the Relay.
What are the other two wires for???
Is the factory Switch Back Lit when the Relay is installed, and powered up??
I used my Google-Fue and AI says that the Factory Light Bar Switch is Back Lit. The back lighting comes on with the head lights. Something good to know.
I will leave that switch in place, and not replace it with the Rocker Switch Pro Switch that I have on order.
