Replacement for stock switch?
The Hiking Viking
Florida
I’ve got two rocker switch blanks on the dash that are connected to wires. One set is labeled Heater and the other is labeled LED Lightbar. Is there and aftermarket rocker switch that will work with the stock Roxor wiring? I’d like to use the factory set up for my off road lights, but the stock switch seems to out of stock everywhere. Thanks in advance.
OTRATTW.com will probably have something that will work. But you will have to match up the plug to the style switch it takes. Keep in mind though, if you use anything larger (in amperage) than what the factory had for lights or heater, you might as well pass on the factory harness and just wire up the accesory direct to the switch of your choice. That way you'll have the proper gauge wiring for the accesssory you're using. (y)
I have the factory switch installed, but not connected to a light bar. My current plan is to replace it with another switch matching what I have (Wiper, Rear Light Bar, Interior Lighting) and wire the Light Bar from scratch. My back lit switch's will then all look alike. Rocker Switch Pros is the brand I went with. Marine Grade.
Thanks, Bob. I just looked at their site. I’ll probably go with the same company.
