Shifting Problems
bordercollie
MS
I bought my Roxor in April of 2019 , The hours are unknown because I used a battery pack to boost it off last year and messed up the milage to just FFFFF on the display, Alll other indicators are fine.
Anyway, that not so important to me but I am having a problem with shifting from a dead stop to 1st gear. It will shift easily if the engine is off and all other gears shift fine while in motion. It's just the 1st geat from a dead stop. Could it possibly be the slave cylinder or do you think it might be something internal and more dreaded? I use it only on our farm so will have to make due if its a big deal. Thanks in advance. bc
Plenty of fluid in slave? I’d start there and then check the throw of the slave. Sounds like it’s not moving the clutch enough.
